Ir para o conteúdo principal
Repair guides and support for laptops produced by Razer.
How to disasseble and clean Trackpad
The left click button on my Razer Blade 14 is acting up, I need to press on it hard to register a click, I think it is caused by dust building underneath it, Can anyone show me how to disassemble the trackpad?
Esta é uma boa pergunta?
Pontuação 1
6 comentários
did OP resolve current having same issue with this and same model
por
Please tell us the make and model of your laptop so we can assist you further.
por
Sorry, its a Blade 14 late 2016 (GTX 1060)
por
@onarye I don’t see a repair guide out there but the trackpad is probably up under the battery. If you really want to have a functional trackpad you will have to take out the battery and try and disassemble it yourself. If you are not confident in yourself just don’t do it, it’s not worth it. If you decide to do it then be careful with the battery because if accidentally punctured it can catch fire.
por
@ajcooke01 Thanks!I had opened and replace the thermal paste of it before, also I found some videos taking the battery off, I think I can handle it, I might take a look on my free time. Thank you for the response.
por
Exibir mais 1 comentário
Adicionar um comentário
1 resposta
Solução escolhida
Open it up and check to see if your battery is swelling and putting pressure on the bottom of your trackpad. Here’s how: https://www.youtube.com/watch?v=MhSzgrto...
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Rye será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 31
Ao todo: 7,115
