Ir para o conteúdo principal
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Perguntas Visualizar todos
My MacBook Pro 13inch 2011 Back cover Display Housing Popping off
hey guys today I shocked when I cleaning my MacBook Pro 2011 13inch , I find that my Back cover Display Housing Popping off from his place ?!! I never made any repairs on my Mac or on the display ! so how I can fix it pls ?!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Your glass may just be coming loose. Here’s how to replace it, you may just need to re-adhere it.Once you have the glass off, take a loo at the frame, these have been know to crack in the lower left hand corner about and inch up from that corner. If this happens it allows the display to flex on opening and closing and allows the glass to pull loose. I use an epoxy to repair this damage
MacBook Unibody Model A1278 Front Display Glass Replacement
Esta resposta foi útil?
Pontuação 2
If I were you I would just replace this so it doesn’t give you fits in the long run. There is an iFixit guide and a new display assembly stocked by iFixit too. You can find the display assembly part under the parts section in the guide I will provide below. Hope this helps.
MacBook Core 2 Duo Unibody Display Replacement
Pontuação 1
Adicionar a sua resposta
xShad0w será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 80
