Ir para o conteúdo principal
High performance tablet computer released by Apple on November 11, 2015. Model A1584.
Random touch responses after screen replacement
After replacing display there are many odd random actions occuring. Ie.. I open YouTube and the fifth video on screen starts playing and soon after starts skipping to next video repeatedly. But YouTube music doesn't do this. Telegram messaging randomly switch to different conversations. But Hangouts messaging does not. I couldn't even type this up in the browser because it will repeatedly delete the message but for some reason it's kind of working in Google keep, it's just randomly selecting text making it difficult. It also randomly pasted my clipboard a few times. It seems to be getting worse. After swapping the display it was just the YouTube issue.
  Yes I fallowed the instructions to the T. Made sure to separate the battery connector before unplugging the display. Is it possible my display is faulty or damaged? My iPad is barely usable now
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
This sounds like a logic board issue, not a screen issue. What happened to the Pad that you had to replace the display?
Esta resposta foi útil?
Pontuação 2
4 comentários:
Dropped it. Screen was cracked. Worked for 5 days before I replaced the screen
por
Are you having any issues or symptoms that would lead you to believe the display is at fault? Any artifacts, streaking, partial display?
por
No, just the random touch events. Note, I am not touching the screen when it happens.
por
I am only assuming it's the display since the iPad was working fine until I replaced the screen.
por
Did you get your screen from iFixit? It should be working 100% perfectly if so, contact iFixit customer support and request a new screen if it’s not working right. If not, there’s a 90% chance it is faulty because getting a new screen elsewhere is a roll of the dice. I suggest you order a new one from iFixit, and watch this guide for installation.
Imagem de This assembly includes the LCD and glass digitizer screen and the display daughter board and flex cables.
Produto
iPad Pro 12.9" (2015) Screen
$249.99
Pontuação 1
2 comentários:
I did purchase the screen from ifixit. I'll contact customer support, ty
por
threethirteeneleven - Big sigh of relief for you, because iFixit customer support works wonders! Have a good rest of your day.
por
Adicionar a sua resposta
threethirteeneleven será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 172
