Ir para o conteúdo principal
The PSP 300x was released in the U.S. on the 15th of October 2008. Repair of this device requires only common tools.
20 Perguntas Visualizar todos
My psp is not showing games.
My psp is not showing games . I have my memory stick also. When I open my games folder it only shows corrupted data
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Does it only show corrupted data for your games folder? Have you tried adding the games back in to see if it shows the same thing?
por
Adicionar um comentário
2 respostas
It's probably your memory card in your ps3 try to replace that then it should work the same thing happen to me and that was the cause of mine if that doesn't work then I dont honestly know srry man
Esta resposta foi útil?
Pontuação 0
Your memory card is corrupted, replace it on immediate basis.
Pontuação 0
Adicionar a sua resposta
Anas Khan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 8
Ao todo: 287
