Ir para o conteúdo principal
Informações de reparo para o Raspberry Pi 1 Model B+. Lançado em julho de 2014. Modelo: B+.
Network (Wired and wireless ) sectors and usb without electricity
My model is raspberry pi b.
When I connect the device to the power, it starts to boot without problems, but there is a flashing yellow mark on the corner of the image.
But the usb section and the network segment do not work.
I replaced the power adapter and cable, but the problem still failed.
There is a part called polyfuse that I tested, which seemed to be healthy.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
By flashing yellow mark, do you mean a lightning bolt in the top left corner? This means that the Pi is not receiving enough power. Have you tried an OFFICIAL Raspberry Pi power supply, and not something like a phone charger?
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
mohammad será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 27
Ao todo: 693
