Ir para o conteúdo principal
Also known as a multitester, or a VOM (Volt-Ohm meter), a multimeter is an electronic measuring instrument used to measure voltage, current, and resistance. Includes handheld and tabletop testing devices.
Non-contact voltage detector not working on Multi Meter
Hi,
I bought a Multimeter from JayCar Electronics today Digitech QM1529 DVM. It works fine but one thing doesn’t work, the non-contact voltage detector.
When I try to use it with the DVM it comes up with - 951 when I’m not even holding it up to something!
I hope there is a fix
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Robbie1155 are you following the manual for this meter?
por
Adicionar um comentário
1 resposta
Solução escolhida
Sorry you have a bad unit you’ll need to return it for an exchange or buy another probe.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thanks I will exchange it :)
por
Adicionar a sua resposta
Robbie1155 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 673
