Ir para o conteúdo principal
4.3" widescreen LCD display with a 333 MHz Processor. Model Number PSP98510. Repair for this device requires common screwdrivers and prying tools.
83 Perguntas Visualizar todos
Will any psp 2000 motherboard work?
I have a PSP 2000 with the TA88v3 motherboard installed. Its bricked.. I'm trying to find out if I can install any PSP 2000 motherboard to fix it. If so, what is the best one to install? or do I need to find a TA88v3? I've heard issues with the voltage being different and wifi not working.
Thanks
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
All of the parts that would commonly be replaced, that is the LCD, disc drive, and joystick are all interchangeable between any 2000 series PSP, at least in my experience working on at least a couple dozen of them. I would be surprised if anything else was incompatible. Besides, I'm fairly certain that the wifi chip is incorporated into the motherboard itself, making this a non-issue.
Esta resposta foi útil?
Pontuação 1
I think you can buy it from AliExpress or any place i dont think for the model or sirial can hard for back from break only model for motherboard and add i see that for psp E1004 motherboard…
Pontuação 0
Adicionar a sua resposta
Don será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 6
Últimos 30 dias: 8
Duração total: 1,394
