2017 trackpad replacement part work in 2018?
Is the 2017 trackpad you guys have for replacements work in the new 2018?
Esta é uma boa pergunta?
Finding the part will be next to impossible. You will void your warranty. How about just removing it and cleaning the dirt out. See step #6 of this guide: MacBook Pro 13" Touch Bar 2018 Teardown If this becomes an issue it will probably get covered like the keyboards have.
Esta resposta foi útil?
thank you! once I get the tool kit I will give it a try!
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 12
Duração total: 331
4 comentários
check this guide for changing touch pad MacBook Pro 13" Touch Bar 2018 Teardown
por Amily Grey
May I ask why you need to replace it?
por mayer
after a few minutes of not using it, on the first click it almost feels as if theres dirt in-between the pad and the click mechanism but its very faint so I know apple will not fix it and if they do it will be sent out for a week to do it so I would rather just replace the trackpad myself knowing it shouldn't be like that because my work one runs fine all the time
por bchiaino
Thank you Emily, I looked at the guide but I didn't see if the 2018 and 2017 use the same trackpad. thank you
por bchiaino
