Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
2265 Perguntas Visualizar todos
Replacing A1660 logicboard with an A1778 on an iPhone 7
Is it possible to replace an A1660 motherboard, with an A1778 one? I destroyed the baseband pad, on my phone’s A1660 logicboard and i need a cheap replacement. The only thing i found, is a model A1778 logicboard. Will the replacement work?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
A1778 ka motherbord ha?
por
Adicionar um comentário
1 resposta
Solução escolhida
Hi Yannis!
Physically, the board will fit fine. Bear in mind however that the models are differentiated primarilly by which modem they use - Qualcomm or Intel. So, it should fit just fine. I would also expect it to work fine, but there may be some performance differences. You’ll also want to be certain that the replacement board comes with its original home button or your Touch ID will not work. Finally, be sure that the replacement board is not iCloud locked or you’ll have a whole new headache.
Cheers!
Joshua
Esta resposta foi útil?
Pontuação 1
2 comentários:
Thanks a lot Joshua. Your answer was pretty informing.
por
You bet! Glad to help!
por
Adicionar a sua resposta
Yannis será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 4
Últimos 30 dias: 8
Duração total: 673
