Ir para o conteúdo principal
A portable, rechargeable jumpstarter that can provide instant jumpstarts for cars and trucks.
24 Perguntas Visualizar todos
Road master power station
I have a roadmaster power station it is been in my trunk dry and not exposed to the weather and went to go use it and the battery is dead I tried to plug it into the AC outlet and it does not charge what can I do
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Try plugging it in and leaving it for a night, then, try using a different power cord, if it takes AC directly.
Sometimes you have to sort of “push and pull” the cells to get them to start taking a charge again.
sealed lead-acid batteries are practically bullet proof.
but if nothing works, gotta crack it open, and change the cell - find a electronics parts store’ - they will give you a reasonable price for the battery - Also remember you can sometimes join 2 batteries together to make the final voltage you need, if you want to Frankenstein it. like if it needs 12v - and you can only find two-6v cells, as long as the amperage is the same or more then they can be joined using a pigtail, i did this for mine a while ago. BUT you would need to read up on doing that properly to not cause a meltdown.
errrrr, you can check the fuse with a meter :)
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Howard mcfadzen será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 11
Duração total: 103
