Ir para o conteúdo principal
HTC's affordable A9s. Released in September 2016 with Android 6.0 Marshmallow
How can I open the backside for battery replacement?
Hi everybody,
Due to the incredibly bad battery performance of my HTC One A9s, I decided not to buy a new phone but to replace the battery. However, I bought the battery and a little stick/tool to open the backside, but it does not open without any potential damage. Since it has a clear opening and something like a groove in its design, it shouldn’t be that difficult, right? There appears to be no information or youtube-vido whatsoever on this topic on the internet, so can anybody help me getting it done?
Thank you a lot in advance,
Kamil
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
4 respostas
Pergunta mais útil
You open the HTC One A9s from the front. The screen is glued down with adhesive. I recommend using an iOpener and a set of Opening Picks.
Here is a YouTube video detailing the repair:
https://www.youtube.com/watch?v=qSWMFBcW...
Imagem de Thin prying tool for opening electronic devices. Opening picks are essential to open any iPad, tablet, or smartphone sealed with adhesive.
Produto
iFixit Opening Picks (Set of 6)
Imagem de No more adhesive battles! With our iOpener, you can quickly and easily remove glued components in electronic devices whether you're a repair professional or beginner. Apply gentle, even heat to loosen the adhesive holding smartphone, tablet, and laptop case components and batteries.
Produto
iOpener
$24.99
Esta resposta foi útil?
Pontuação 1
Thank you so much! But that video is for the A9, is it the same procedure for the A9s? Thanks!
Pontuação 0
you go in through the front
Pontuação 0
Same problem for me the A9 seems totally different to A9s,
A9s looks like rear panel to access for battery access
Pontuação 0
Adicionar a sua resposta
Kamil Bernaerts será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 190
Ao todo: 2,708
