Ir para o conteúdo principal
Released September 2013, identified with model number T100T. 2-in-1 portable with Quad core Intel® Atom™ processor and 2GB of RAM.
Not charging, only recognizing plugged in and stops
I plug in the charger. The device recognized that it was plugged in but only blinks orange a few times, shows low battery on the screen(no lightning) and then screen goes black and the orange light is no longer on as if it's not plugged in.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
It seems your cable may be faulty try to change the cable of your charger but make sure you select correct range of products.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Jolene será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 386
