Ir para o conteúdo principal
Lançado em junho de 2012, modelo A1278. Processador Intel com Turbo Boost, até 512 MB DDR5 de RAM vídeo
1624 Perguntas Visualizar todos
Mac OS X Lion to el capitan
After two tries on downloading el Capitan to my mac it comes as a folder in finder, but when I click it, it says something by the lines of “the following disk images couldn’t be opened”.
So, i’m not really sure what to do. My goal is to end up with High Sierra, is there any other way to go from X Lion to High Sierra, or is there a way to download el Capitan in 2018 with out the same problem that i’ve been having previously?
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
Please tell us the exact MacBook Pro you have. To get that information you can plug in your serial number from the back of the machine here and it will tell you what you have: https://everymac.com/ultimate-mac-lookup...
por
It says MacBook Pro "Core i5" 2.5 13" Mid-2012
Is this what you mean?
por
Adicionar um comentário
1 resposta
If you have a good internet connection why don’t you just use internet recovery to install the newest OS. Here’s more on it: How to reinstall macOS
But you may have a deeper issue here! The 13” Unibody MacBook Pro’s tend to have issues with its HD SATA cable. I strongly recommend you replace it if you just upgraded your drive. Here’s the part you’ll need: MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable. You’ll want to place some electricians tape un the uppercase where the cable crosses over. The rough surface of the aluminum case tends to wear the cable. You also don’t want to over fold the cable you want smooth arcs not sharp corners.
Imagem de MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable
Produto
$34.99
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Sophia Jeffery será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 207
