Ir para o conteúdo principal
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
Power On, Power Off
So, I found an old DS in my house that was broken for a while. Every time I powered it on, the green light on the “middle” part of the DS turns on, the bottom screen flashes white. Then, the green light changes to orange and quickly shuts off. I believe there may be a loose connection near the part where the top and bottom display connect. The only way to actually get it to work is to push back the top display really hard. Any fixes?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi!
Sounds like a loose connection between the upper screen and the rest. Try dissasembling the console and reconnect the upper LCD ribbon cable. Follow this guide all the way to step 16: Nintendo DS Lite Rear Display Bezel Replacement
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Daniel Greff será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 117
