Ir para o conteúdo principal
0.622kg (1.4 lb) tablet with a 10.8 inch display and 3 position kickstand released by Microsoft on May 5, 2015. Model number: 1645.
Where can I get a Wi-Fi assembly replacement?
When I was trying to replace my screen, I damaged my Wi-Fi antenna and am in need of a replacement. Does anyone know where I may find one for sure? I’ve tried eBay but haven’t had any luck. I don’t want to have to take apart another one just to get the antenna as I’ll probably cut that one too.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Where are you located? Might be able to help you out.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Texas. East Texas. Closest major city is Houston.
por
I'm in Australia unfortunately. Hopefully you'll find someone that has spare surface pro 3 parts locally.
por
Adicionar a sua resposta
perezd será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 124
