Ir para o conteúdo principal
Repair guides and support for televisions manufactured by Sony.
748 Perguntas Visualizar todos
Vertical Lines On TV that appears and disappears
My Sony Bravia TV randomly started having vertical lines across the screen at different areas. It would appear and disappear at times. I realised that by turning the power off (standby mode) and turning it back on, the lines would disappear for around 5 minutes but reappear again later on.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
I have a similar problem on my XBR 75X850D. During and after most recent firmware update the vertical lines and bands appeared. Sometimes on/off make them disappear, sometimes not. Very frustrated after 2.5 years of flawless enjoyment. How did you resolve the issue?
por
Adicionar um comentário
4 respostas
Pergunta mais útil
If changing HDMI port solved your problem, then spraying the bad port with contact cleaner and inserting a clean (new) HDMI cable into and out a number (6-12) of times can clean the contacts. (After unplugging.)
But if the contacts are worn or bent out of alignment or otherwise not making good contact the only other fix is to replace jack.
The problem happening after being on for 2-5 minutes, tells me that the buildup of heat causes changes in the shape of the metal contacts in the HDMI jack.
Esta resposta foi útil?
Pontuação 1
This may be due to a bad connection to screen at edges. Try squeezing the edges around the perimeter of screen to see of lines come and go.
Pontuação 0
2 comentários:
Tried above, nothing changed. However, I unplugged antenna connected to the TV via coax cable. This seems to reduce the line appearance frequency from every few minutes to every 30 minutes.
Hopefully this can hold until the next firmware update.
por
Actually, no much improvment, after a while it display vertical line every 2 minutes again.
por
Change those crappy, freebie HDMI/COAX Cables. (Or just weathered out ones, worked for me, hope it works for you)
Good Luck !
Pontuação 0
I was seeing vertical line appearing on and off on my Sony Bravia while watching my Apple TV. Changing to a new HDMI cable didn’t work. I had to use another HDMI port and when I turned on my Apple TV no more lines. It’s disappointing to know I lost a port though.
Pontuação 0
Adicionar a sua resposta
awesomepossum será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 20
Últimos 30 dias: 81
Duração total: 3,246
