Fixing EPSON EB-W130 that doesn't turn on (and no LEDs light).
Hi,
I’m in the process of fixing my Epson EB-W130 projector.
The projector doesn’t turn on or show any indication of powering up (power buttons do nothing and no LEDs light up when power is applied).
I’ve been trying to locate the service manual for it. (Note this is different to the user manual).
So far google searches have only returned the user manual.
Does someone know where I can find it? Or perhaps point me in the right direction to obtain it please?
Cheers,
James
Update (20-Aug-2018)
Currently my investigations point to the main power supply (main PSU).
I’ve found:
- 2 fuses - all intact still.
- 1 thermal fuse - which is operating correctly.
- 240V AC (Australian mains) is measured on the main PSU board successfully.
- Probing the main PSU shows that it’s output to the processor PCB is 0V DC (expecting 17V DC according to the silkscreen on the main PSU board). I’ve even hooked up the oscilloscope to see what the main PSU does when power is applied. Nothing, there’s a small flinch in the voltage level but nothing to really indicate that the power supply powered up and had it’s output disabled by the processor board. There’s not even any activity on the optocouplers that pass control signals from the processor board to the primary side of the main PSU.
- Disconnected the main PSU from the processor board. I read 10 V DC on the output (expecting 17V DC according to the silkscreen). The oscilloscope shows a very clean 10 V DC signal.
- I try connecting the power supply to the processor board again, this time with the optocoupler signals disconnected to make sure there’s no ‘kill’ signal being sent to the main PSU. Power on, and the supply’s output measures in at 0 VDC again.
Perhaps the main PSU is not working properly (indicated by 10VDC being measured instead of 17VDC). It could therefore be struggling to source enough power for the processor board to boot up?
I’ve started reverse engineering the power supply a little to double check that the PSU IC, transistors and other components are working/biased correctly. (This is where I was hoping for a service manual to help me along). Nonetheless I will continue investigating.
At this stage I’m not sure if I can trust the 17V DC marked on the main PSU’s silkscreen. I have thought of powering the processor board using my bench PSU - I just don’t want to risk damaging the processor board until I’ve investigated the input range it can handle. I see switching regulators, so perhaps it has some tolerance to input voltage. My thought is - if it powers up from the bench supply and provides some activity on the status LED’s then that’ll add evidence to the problem existing at the main PSU.
Esta é uma boa pergunta?
2 comentários
I have the H729A/VS240... no LED for power or any other indication of power. Plug is good. 120v to and thru the power board. Any help on checks past that point would be helpful.
por Rob Combs
My Epson HC2150 just shut off mid watching… it also has no lights etc. I unfortunately do not have your experience so not sure if I'm S.O.L.
por charles shyne
