Flash on my Nikon P7700 camera will not pop up.
The flash on Nikon P7700 is stuck. It will not pop up.
Esta é uma boa pergunta?
Thanks James. In my case, the flash does pop up after a few tries. I have to release the latch with a jerk. That helps the flash to pop up. Looks like there is a spring under the flash which has lost its tension with time or maybe the latch might be worn out now.
Esta resposta foi útil?
My Kodak has the same problem. I think the little relay that unlatches it is just a little off adjustment, so I give it a little help with my fingernail sometimes. Either yours is out of whack due to wear or misalignment (damage?), or just permanently broken.
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 361
