Ir para o conteúdo principal
The Samsung Galaxy Note 5 (called the Note5) is a phablet-style phone with stylus, manufactured by Samsung, released in August 2015.
Battery temperature too high
Got a new battery in my note 5. A few days later, it's telling me charging paused, battery temperature too high. Battery temperature is normal though.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Pergunta mais útil
Probably the battery is faulty giving incorrect battery temperature information, I usually see the battery temperature too low message meaning liquid damage near the charging port area (where the thermistor component is).
Esta resposta foi útil?
Pontuação 2
3 comentários:
Thank you for your input. The battery is new and original. I recently (a few days) replaced it. The notification disappeared now. Battery is charging, but not exceeding 67%.
por
This might be a long shot but is the phone up to date for software updates (Android OS updates) in settings?
por
Thanks Ben. OS system up to date. I am noticing now they it is charging sometimes, And charging is paused sometimes. Can't quite figure out when and why. Today when it paused, i pulled the cable and blew some air in the hole. It restarted charging. Can't figure why either. Is charging overt 67% now, 82 and going up.
por
Adicionar a sua resposta
E B será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 20
Ao todo: 3,456
