Ir para o conteúdo principal
The third-generation Ram was unveiled on February 7, 2001 at the 2001 Chicago Auto Show. This was a major update including an all new frame, suspension, powertrains, interiors, and sheet metal.
81 Perguntas Visualizar todos
When truck is off stereo and windows stay active
Just recently purchased an used 2003 Ram 1500. Only issue is battery keeps draining and I have found the cause is when truck is completely off the windows and stereo equipment still work until the battery is completely drained. What could be causing this?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
My car used to do that too. It was because the switch that turns everything off when you open the door was stuck in, so it wouldn’t turn accessories off. You know, like the light in the fridge??
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Kendra Gilliam será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 27
