Ir para o conteúdo principal
Released on July 28th, 2017, the New Nintendo 2DS XL is a handheld gaming console succeeding the Nintendo 2DS.
20 Perguntas Visualizar todos
Top Screen Replacement Front Panel looks cracked too
Ok here is the deal
I have a Nintendo 2DS XL with a cracked screen
Took it apart to replace the screen with a new one
The front plastic panel or front piece of the 2DS still has glass on the back of it and it is cracked. My question is this glass the front of the old screen and does it need to come off to put the new screen in?
FYI The glass behind the front top plastic is what looks cracked not the plastic itself - wanted to clarify.
Or is it a separate piece that needs to replaced too and if so where do u get it?
Thanks in advance Jamie
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Nintendo uses paired LCD and digitzer setups so yes, glued on cracked screens are still cracked screens. Yeet the old part out the door and enjoy the fact that you have made it far enough to get to the screen without breaking anything.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Jamiemr3 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 283
