SSD: SATA to USB cable
Would using a SATA to USB-A cable work to connect a 3D NAND 2.5” SSD to a 2009 MacBook Pro 13” as an external storage device? Would I need to format it? If so, how?
Esta é uma boa pergunta?
You really want a 2.5” drive case to hold your drive in. Something like this would do: 2.5in USB 3.0 SSD SATA Hard Drive Enclosure. It will have the needed drive interface.
You would need to format the drive with Disk Utility before you could use it.
Esta resposta foi útil?
Okay. Thank you!
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 232
