Ir para o conteúdo principal
15" HP laptop with a 2.16 GHz Intel Core2 Duo Dual-Core Mobile Processor, released in 2008.
5 Perguntas Visualizar todos
Laptop not turning on, DC jack has light
Hello. My laptop, an HP dv6700 does not turn on.
The power jack glows but when I press the power button, nothing happens.
Also, the 3 LED indicators, are all off when I plug in the adapter.
If the battery is connected, all 3 LEDs turn on and stay lit.
The laptop does not turn on in any way.
Anyone have a clue?
Thanks.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hello,
Have you tried turning it on with the power cord plugged in, and the battery removed?
Esta resposta foi útil?
Pontuação 0
2 comentários:
Yes, nothing happens. The only difference is, battery installed all leds on the bottom left are always lit, when the battery is removed, all leds are turned off.
por
It could possibly be bad ram or CMOS battery
por
Adicionar a sua resposta
Alkis será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 6
Duração total: 458
