Ir para o conteúdo principal
The BLU Life X8 is an unlocked Android smartphone (similar to the BLU Life 8 or BLU Life XL) that was released in July of 2015. It can be identified by its Global Trade Item Number 00848958020011.
Phone over heats/broken micro SD card
How do I remove the broke piece of micro SD card still inside?
Second question is there a setting to control app permission to stop apps from having access to everything as the phone gets to hot to hold?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Sometimes these can be removed using fine tweezers or razor blade depending on how the SD card slot is covered.
It’s probably the broken microSD card causing a short-circuit on the phone making it heat up a lot.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Stev Reid será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 5
Ao todo: 121
