Ir para o conteúdo principal
Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Perguntas Visualizar todos
USB Ports not working
Hello,
So I have problem on my Mac with usb ports. First USB port(left one on the side) doesn’t work at all, it doesn’t give any signal. Another USB port is barely working. With external hard drive in it it shows me error “usb accessories disabled - unplug the accessory using too much power to re-enable usb devices” but hard drive is spinning and lightning.
When I plug my phone, it starts charging it but not showing up on desktop. Tried few USB sticks but still not showing up.
I was googleing a lot, did the SMC and NVRAM reset and still the same, looks like a hardware issue.
I want to know which part exactly needs replacing and where can I get that part because changing logic board is too expensive, doesn’t worth it for this old mac but it’s still i7 and holding strong.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
I Have the same problem too, to fix any usb port on MacBooks, the motherboard needs to be replaced, there is no other option if is a hardware problem
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
darko.sajic será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 456
