Ir para o conteúdo principal
The Galaxy S7 Edge is the curved-screen variant of Samsung's 2016 flagship phone, the Galaxy S7. Announced February 2016 and released on March 11. Model SM-G935.
369 Perguntas Visualizar todos
Loudspeaker hissing and "snow" noise
Repaired a customer’s S7 Edge screen and the loud speaker stopped working. Customer brought phone back when the new part came in and I noticed when it was dropped off that the loudspeaker was making a hissing noise and sounded like snow on a TV. After replacing loudspeaker, the problem did not go away. I had a spare S7 Edge at the shop (as all it does is bootloop), took the loud speaker out of it, and tried the 3rd speaker with customer’s phone- same problem.
Everywhere I look, the answer seems to be software/app related. I looked at the board, and compared it to other boards. No signs of a burn or short or missing chip/bent prong, etc.
So, to recap, his original speaker stopped working after screen replacement. He took the phone with him until parts came in. When he brought it back, the loudspeaker was making a hissing noise. Replaced loudspeaker with new part- still hissing. Tried another part from a different source- same problem.
Any suggestions?
Thanks in advance!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hello,
The only cause I can see is either a software problem, then maybe a factory reset could help, or a component from the motherboard that is causing this problem.
I hope it helped you a bit
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Trevor Brodie será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 296
