Gauges and lights not working on dash BUT the hazards do! Help!
All of the lights are out and none of the gauges are functioning BUT the hazards (blinkers) are still working. I have disconnected the neg terminal from the batt, tried the reset (ignition on off position and holding in the odometer reset) but reset light never displays. I have checked every fuse, as well.
What else can I do?
TIA
Esta é uma boa pergunta?
Pontuação
0
i had this problem in my Barina. turned out to be the fuse for the dash display. I know you said you checked all the fuses but it may be worth replacing it anyway and seeing it that works
por pollytintop
