Ir para o conteúdo principal
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
467 Perguntas Visualizar todos
Only LED 1+2 and no chime, fans + HD spins
I just bought an iMac late 2009 3.06GHz Intel Core 2 Duo (E7600) but it has some issues. It does not boot, and no startup chime. LED 1 is always on (so PS is good?). LED 2 comes on when pressing power, so does the hard drive (I can hear it spins) and fans run normally (once I forgot to put in the display temp sensor and fans went full speed). However a few seconds later, LED 2 goes dark and hard drive + fans stop. PP12V_S0_PS on power supply also drops from 12V to 0V (see measurements below). Then LED 2 comes on again, hard drive and fans starts and PP12V_S0_PS is back to 12V, and they stay powered until I manually power it down again. Can someone confirm this LED 2 on/off/on is normal or faulty behaviour? Seems strange to me. Also there is no backlight in the display. No signal to external monitor.
Anyway, lacking light in LED 3 I figured this is a GPU issue. However, I removed the GPU and still getting the LED 2 on/off/on behaviour. Still no startup chime. So I can't rule out logic board or CPU. Logic board is Apple 820-2507-A. Also removed all memory, inverter board and BT module to see if behaviour changed. No luck.
The previous owner attempted repair on this and accidentally ripped off the display port connector without desoldering while removing the display. It also has a burned ferrite bead (L5720, noise filtering between MOSFET and motor control signal to CPU fan). I temporarily shorted this to get CPU fan running (in case there is some logic not powering the CPU if fan is faulty). Due to poor storage after failed repair, a transistor (Q5605) got whacked loose. This is a 2N7002 (60V 210mA N-MOSFET) for switching the HD fan, and I replaced it with a BSS138PW (60V 320mA N-MOSFET). All fans run great now.
I measured the power supply according to this pinout: http://hqlaptoprepair.co.uk/wp-content/u...
STANDBY:
--Left--
INVERTER-: 0V
INVERTER+: 3.3mV
INVERTER+: 3.3mV
PP12V_S0_PS: 3.3mV
PP12V_S0_PS: 3.3mV
PP12V_S0_PS: 3.3mV
SMB_ACDC_SDA_RC: 0.66V and ramping up (2 min later, 0.78V) (same as SCL, I2C communication?)
GND: x
--RIGHT--
INVERTER-: 0V
GND: x
PS_ON: 4V
GND: x
PP12V_G3H_ACDC: 12.07V
GND: x
SMB_ACDC_SCL_RC: 0.66V and ramping up (2 min later, 0.78V) (same as SCL, I2C communication?)
GND: x
POWERED:
--Left--
INVERTER-: 12V between INVERTER-/+
INVERTER+: 12V between INVERTER-/+
PP12V_S0_PS: 12.07V
PP12V_S0_PS: 12.07V
PP12V_S0_PS: 12.07V
SMB_ACDC_SDA_RC: jumping between 3.253V and 3.372V
GND: x
--RIGHT--
GND: x
PS_ON: 0V
GND: x
GND: x
SMB_ACDC_SCL_RC: jumping between 3.253V and 3.372V
GND: x
It's an old iMac and slow compared to todays standards, but still performs good for designing PCB with its solid 27" screen. I really hope to get this baby up and running again.
Any help is appreciated. Thanks!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Led 1 + Led 2 should be turned on when the imac runs. 3rd is for the GPU, but if you remove it, you should still see LED1+2. Can you try it without a HDD and see if it starts and the 2nd led stays on? Maybe its just a corrupted OSX install that reloads on boot.
Here is the service manual for this iMac, you might be able to find something useful: http://tim.id.au/laptops/apple/imac/imac...
Esta resposta foi útil?
Pontuação 1
4 comentários:
I've tried every possible combination of removing modules (memory, CPU, GPU, hard drive, optical drive, backlight inverter) with no luck.
por
Could be the PSU? When something draws more power it restarts? Thats my best guess.
por
One more thing, make sure you have at least one ram installed... i spent my whole day taking it apart and putting it back together. Without a ram i only got 2 leds...
por
I've tried back and forth with 1 (in case one was bad) and 2 modules, switched them around in the 4 slots. No luck :(
por
Adicionar a sua resposta
okwestern será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 627
