Kenmore 11021302013 Spin cycle and spin issue.
I have a kenmore 110.21302013 washer, we recently had an issue with clothes still being soaking wet like it hadn’t been spun out. We would end the cycle and turn it to drain/ spin and it would work just fine. The problem has gotten worse and now many times when i select drain and spin it pumps out any water and you can hear the bin start to move. the motor powers on for a few seconds to spin it and it stops. Many times the lid lock will just be flashing and it requires me to unplug it to reset it to get it to unlock. I metered the switch per the tech sheet and it all came back good. i was also suggested to change the Washer Actuator Part #: W10006355. I replaced that today and still have the same issue. I followed the metering checks in the booklet and everything came back good. When doing the manual tests when i turn it to high or low speed spin it starts to spin for about 2 or 3 seconds and seems to fault out. All other tests run just fine and stay on until commanded off as they are supposed to.
Esta é uma boa pergunta?
