Ir para o conteúdo principal
Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Perguntas Visualizar todos
Why is my MacBook battery condition so poor after recently replaced?
I have a MacBook (13-inch, Aluminum, Late 2008) I got the battery replaced around 1month ago and when you click on the percentage the battery condition shows service battery, it only has 29 cycles. Anyone know why the condition is so poor even though the battery was replaced recently and has a low number of cycles. This is the battery information from the system report.
Battery Information:
Model Information:
Serial Number:
Manufacturer: DP
Device Name: bq20z95
Pack Lot Code: 0
PCB Lot Code: 0
Firmware Version: 0
Hardware Revision: 0
Cell Revision: 0
Charge Information:
Charge Remaining (mAh): 409
Fully Charged: No
Charging: Yes
Full Charge Capacity (mAh): 1441
Health Information:
Cycle Count: 29
Condition: Service Battery
Battery Installed: Yes
Amperage (mA): 767
Voltage (mV): 12082
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Who’s battery did you get?
I would review this Apple T/N Apple Portables: Troubleshooting MagSafe adapters. Make sure you're using the correct charger and the MagSafe chargers cable and connector are in good shape, also check the systems connector too.
Esta resposta foi útil?
Pontuação 1
4 comentários:
The brand of the battery is RoHs, it was never used.
por
@ronaldofrity Rohs just indicates compliance to a directive about dangerous goods (https://en.wikipedia.org/wiki/Restrictio...)
If full charge capacity is 1441mAh as indicated, it is a faulty battery that needs replacement. Even an iPhone's default battery capacity is above that.
por
It used to be in good condition but became in such poor condition in less than 30 days. Any reason why it might have died down so fast.
por
Where did you buy it?
You need to get a replacement. Otherwise you'll need to buy another, this is a defective battery.
por
Adicionar a sua resposta
Ronaldo Frity será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 121
