Ir para o conteúdo principal
Model A1418 / Mid 2014 / 1.4, 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
50 Perguntas Visualizar todos
iMac CPU + Ram Upgrade Compatibility
I am looking to upgrade my Mid-2014 iMac. It currently has a core i5 1.4 GHz processor and 8GB of DDR3 ram. I have found a kit of 16gb of ddr3 ram, but I don't know if it is compatible: http://www.crucial.com/usa/en/ct2k8g3s13...
I was also looking to see what the maximum compatible CPU that the iMac is able to handle that is also under $250.
Thanks!
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
Got some bad news :-{
Your system has a soldered in CPU so it can’t be replaced, to add to this your RAM is also soldered in!
Here’s the IFIXIT logic board replacement which you can clearly see things iMac Intel 21.5" EMC 2805 Logic Board Replacement
Sorry
Esta resposta foi útil?
Pontuação 4
1 comentário:
thank you!!!
por
Adicionar a sua resposta
Armaan Bassi será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 8
Últimos 30 dias: 28
Duração total: 3,661
