Bluetooth showing unavailable on MacBook Pro 13 inch 2009
I recently changed the battery, trackpad, and replaced the logic board.
Now the bluetooth is showing unavailable... Any ideas how to fix this?
Esta é uma boa pergunta?
Did you access the AirPort its self? If you had you might have reversed the cables.
Esta resposta foi útil?
Turns out it was a internal issue, I took the display apart, took off the clutch, and the cable that connected to the bluetooth card looked off, so i replugged it. Works fine now.
Happy all’s well - Don’t forget to score & accept the answer.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 208
1 comentário
Go into About this Mac> System Report, open the USB on the right do you see the Bluetooth Host Controller.
por Dan
