Ir para o conteúdo principal
This is the first generation of the Ford Escape, a compact crossover SUV. Production started in 2000 for the 2001 model year.
104 Perguntas Visualizar todos
2005 Ford Escape is stuck in park and no brake lights.
Brake switch is fine, no brake lights and stuck in park . I can over ride the safety lock to drive the vehicle but no brake lights. I have been told about a million reasons?I would think that the Shift interlock solenoid would be next? Any suggestions before i tear the console apart? Thanks.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
I had a similar problem on the same model vehicle.
I ended up switching out the gear shiftier assembly with a used one and it worked again.
Not sure how much help that was, but figure id share my success.
Good luck!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Ian Ochitwa será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 779
