Ir para o conteúdo principal
Announced in August 2017, the Galaxy Note8 is the successor to the recalled Galaxy Note7. The Note8 was made available to the public for purchase in September of 2017.
148 Perguntas Visualizar todos
Why is my phone call volume is really quite?
I recently installed a white stone dome glass screen protector and it looks like I got some of the resin glue in the earphone port on the front of the screen. Now when I talk on the phone it sounds like the person on the other end of the line is really far away. I don't know if there is an easy way to clean it out with a sharp needle or something. I would rather not take my phone apart so if someone could suggest a glue dissolver that will not hurt my phone or a way to clear out the mesh I would really appreciate it.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
If you are comfortable opening a phone, you can actually remove the earspeaker on the note 8 prior to cleaning so that you dont damage it and you wont have to be as gentle with the mesh.
Esta resposta foi útil?
Pontuação 0
3 comentários:
When you say I can remove the earspeaker prior to cleaning are you talking about the speaker grill on the front of the phone? You are saying I can remove that without opening up the phone? Is there a how to somewhere online that shows how to remove that without opening the phone?
I appreciate the response by the way.
por
Sorry if i gave you false hope, you definately have to open the phone. I'm refering to the speaker being removable, I don't know about the mesh. I'll be sure to get back to you if I get the opportunity to see about removing the mesh.
por
I found another forum somewhere that fixed my problem. At least it seams like it fixed it for now. I just hope it didn't do any damage to my phone that I don't know about yet. It said to use some kind of glue disolver on the speaker mesh. I used goo gone on a Q tip and rubbed it for a little, then used a tooth brush to get the bristles of the brush into the holes of the mesh. The broke up all the glue really well. I also mixed in using rubbing alcohol every so often to dry up any of the goo gone that got past the speaker mesh and was sitting in my phone. I tried not to let the goo gone sit on my phone for too long. The goo gone worked great and my speaker sounds a lot better now. I just hope the goo gone didn't do any damage to the speaker. Only time will tell.
por
Adicionar a sua resposta
Alex McMaken será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 6
Duração total: 224
