Ir para o conteúdo principal
The Ram line was redesigned for the 1994 model year. Development on a second generation began in 1986, ending in late 1992.
Computer malfunction, reset possible?
The main snap together wiring was removed while the engine was running. Now runs super retarded. can I reset?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
With the engine off, cycle the ignition on and off 3 times quickly leaving the ignition on the last time. The odometer will display the codes in the PCM. f the codes are not active you may be able to clear them with the odometer reset button. If this does not work you will need a OBD scan tool to clear the codes.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Jack Heringer será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 45
Ao todo: 500
