Ir para o conteúdo principal
The Polaroid SLR 680 camera is a single-lens reflex camera with built-in electronic sonar autofocus and flash.
Autofocus won’t focus close up
My SLR 680 will adjust autofocus on objects far away but won’t focus down to 12” like it should.
How can I repair this?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
This is a problem probably not fixable by yourself. The most likely cause is a photoelectric sensor proprietary to Polaroid and not available in the market. It may even be no longer available as spare part by the original supplier. Maybe you can cannibalize a similar Poaroid Autofocus camera. The component is called Pickoff Assembly.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Sergio será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 9
Ao todo: 1,202
