Ir para o conteúdo principal
Is the top case for the 2008 MacBook Pro (A1260) compatible w/ A1226?
The top case for my 2007 MBP 15" (A1226) needs to be replaced as it's quite worn down and I have recently come into possession of a top case for a 2008 15" MBP (A1260), and I was wondering if I would be able to install the A1260 top case on my A1226.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Yes, it will work:
MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Upper Case Replacement
Esta resposta foi útil?
Pontuação 3
3 comentários:
Thanks, I found that myself and already did the swap.
Btw, any idea what version of Mac OS would be the best (read: fastest) with a c2d, 4gb of RAM, and an HDD? It's only a temporary setup at the moment, but I'm wondering if it's Mavericks, El Capitan (I vividly remember Yosemite running terribly on it and Mavericks running well), or something earlier.
por
Which machine do you out of these three:
https://everymac.com/ultimate-mac-lookup...
Do you plan to max the RAM out? How much storage space are you currently using?
por
It's the 2.2ghz late 2007 mbp w/ 4gb ram. The HDD is 320gb that I swapped in a few years back and is more or less empty.
I don't plan to change anything.
por
Adicionar a sua resposta
ddwoskin será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 120
