Ir para o conteúdo principal
Dispositivos de assento de plástico para pátios, áreas de piscina e apartamentos de solteiro.
Damage to clear chair
There was a number written on bottom of clear acrylic chair I purchased. I tried to remove it first with glass cleaner. No luck. Then I used nail polish remover. It removed writing (looked like black sharpie) but left area foggy, no longer clear. How can I restore?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
4 respostas
Solução escolhida
Nail polish remover generally contains acetone or ethyl acetate both of which dissolve plastic. You could possibly buff it out but you are going to make a much larger area involved. IMHO further repair attempts are going to be futile. Live with it.
Esta resposta foi útil?
Pontuação 5
Lookup a technique called "chemical polishing". It uses a solvent of the material and a way of "rolling" the papertowel / rag so only fresh solvent is wiping the surface. I do it on car headlight lenses, but it took a fair amount of practice. I use a liquid acrylic glue, but straight acetone should work.
Pontuação 1
Paint Thinner - oil based, great discoloration remover and will make the PVC or plastic shine - use dawn dish detergent to clean the oily residue after you remove all the stains.
Pontuação 1
Next time try ISO alcohol. I find it removes permanent marker ink.
Pontuação 0
Adicionar a sua resposta
Marilyn Hartley será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 40
Ao todo: 2,887
