Ir para o conteúdo principal
Controle PS4 modelo CUH-ZCT1. Lançado em novembro de 2013 pela Sony Computer Entertainment, este controlador de seis eixos com bateria de íon de lítio de 3,7 V é simples de reparar. (NOTA: O guia de desmontagem NÃO é para este modelo)
How do I fix my controller stuck on G on keyboard?
So basically I got this pre owned controller and when I go to type it glitches and stays on the G button, no matter what I do. I tested out the controller in-game and again, it spams certain inputs. I have bought a cheap wired controller and it appears that the problem was the touchpad AND the L3 and R3 buttons. So my question is how do I fix this and is there an option rather than purchasing a controller. Also is there a way to plug a headphone jack into the PS4 if there is no way to fix.
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
4 respostas
Pergunta mais útil
Repairing the controller in this case sounds impractical. I would just buy a new controller.
There is a reset button on the back of the PS4 controller you could try.
There is no way to connect headphones to a PS4 directly, only through the controller.
Esta resposta foi útil?
Pontuação 1
1 comentário:
you can absolutely plug a mic and headphone in the usb plug of your ps4 and a adapter that you plug them in , thats i plug my headset with my mic
por
i think you have to get your controller fixed or try to fix it your self and you would have to open the whole controller
Pontuação 0
Restarting the PS4 usually fixes this issue, as rebooting any device fixes most issues. Do note that the bug will reappear after a while. I have this same exact issue with a controller I brought a month ago and restarting the device is the cheap way to do it. If that doesn’t work, reset the PS4 controller, which is a small button underneath the L2 button. You might need a paperclip or a mechanical pencil to press this button.
Pontuação 0
I did all of this and none of it worked. I tried forgetting and reconnecting the controller restating the game and updating it.
Pontuação 0
Adicionar a sua resposta
Josef Baydemir será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 48
Ao todo: 13,116
