Ir para o conteúdo principal
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
580 Perguntas Visualizar todos
Backups to external hard drive unsuccessful every time.
So, this MacBook Pro is not backing up to an external hard drive and I've done everything I can think of to diagnose the problem but still haven't gotten anywhere.
I try and backup to the drive and it says:
"Time Machine couldn't complete the backup to "<> Backup".
"An error occurred while copying files. The problem may be temporary. If the problem persists, use Disk Utility to repair your backup dis.
Latest successful backup: 20 May 2018."
I brought it to Apple to see what they had to say and they were useless and offered no support whatsoever.
I have ran First Aid on the Disk through Disk Utility and I'm still stuck. I have another Backup drive that also does the same thing... There are no available updates or drivers for either of the drives. It used to work but isn't now. I've tried all the USB ports on the machine. So, I'm a bit stuck.
The two drives are:
a Seagate Backup Plus Slim (main disk)
a G Drive mobile USB.
As I said, both used to work but now it just doesn't. Preparing backup takes a very long time too before it starts the process but then comes up with the error soon after.
Thanks,
Sam.
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
Did this start after a security update and what system are you running?
por
@mayer I don't remember, sorry. I'm running the latest version of the operating system. In the Apple store, they updated it as I wasn't on the latest release. Hasn't made any difference though.
por
Adicionar um comentário
3 respostas
You probably thought of this already, but is there enough space left on the external drive.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Yes, on both.
por
Just to add, I am on the latest version of High Sierra.
Pontuação 0
Still haven't worked it out :/
Planning to upgrade to one of the new MacBook Pro's, but will still need a backup made.
Pontuação 0
Adicionar a sua resposta
Sam Mileberg será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 10
Duração total: 411
