Ir para o conteúdo principal
A programmable brewing machine by Keurig. This coffee maker uses K-Cup Pods and K-Carafe Pods to brew a variety of hot and cold drinks. Model Number: K2.0-400 Serial Number: 401.0200.1410931
Cannot close cover, how do it fix it?
I opened it to insert a Kcup and now it won’t close. How can I fix it?
Esta é uma boa pergunta?
Pontuação 11
1 comentário
Thanks, I can make coffee now. There has to be a better permanent fix. Maybe replace a part?
por
Adicionar um comentário
5 respostas
Pergunta mais útil
I am not sure if this is the exact model, but try this I found on YouTube:
Workaround: https://www.youtube.com/watch?v=Lenlr8zA...
Fix: https://www.youtube.com/watch?v=0Mg43v6v...
Esta resposta foi útil?
Pontuação 2
1 comentário:
The workaround works great. The actual fix is too complicated for me. Lol! At least I can still use it. Thank you!
por
We were able to lift up on the cover and push down on a  black plate and it closed until we ordered a new one.   I am still searching for a repair because it was one of the better Keurig’s
Pontuação 1
2 comentários:
I have the same problem and also found that pushing the bottom plate down allows me to close the Machine
por
What part did you order .? I can’t seem to see what the problem is although pushing the lower plate down allows it to work I cannot figure what needs the fix obviously the unit is old enough that trying to have it repaired simply isn’t worth it
por
My kcup Is off-track how do I fix it
Pontuação 0
can not get the lid to close keurig 2.0
Pontuação 0
How to close the lid
Pontuação 0
Adicionar a sua resposta
Katherine Harrington será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 20
Ao todo: 20,074
