My S Pen broke off, half still inside, how can it be removed?
Help get SPen out of phone?
Esta é uma boa pergunta?
Smack the bottom of your phone or lightly hit it on a table, it should come right out when you shake it!
Esta resposta foi útil?
This worked for me, thanks.
purrrrfect solution , thank you
Worked for me too thanks!!
This worked thanks alot. ?
Worked great for me. Thanks!
Tweezers? Here is a video of someone getting one out:
My S pen broke outside phone and i put it back in there Not thinking. The pen came out but part of the plastic encasing remained inside. How can I get this to come out?
Mine was stuck way inside the phone. I used a drill with a tiny drill bit and drilled into the hole in the stuck s pen. All you have to do is simply pull it out. It ruins the s pen, but you can get a replacement on Amazon
you can use a phillips screw driver and insert it inside. it worked best for me to take out the broken s pen inside.
Yay! the screwdriver is the only thing that worked for me! thank you so so much!
I used the old-type iron twist serving to prepare a hole in the wood plate for screwing-in the screw. I think this is the best solution!
Últimas 24 horas: 1
Últimos 7 dias: 20
Últimos 30 dias: 92
Duração total: 22,113
2 comentários
I used a lock picking tool it had a hook on It tried for 30 min then I prayed put it back in felt it move and out it came .
por Beth ann Poole
Grateful it worked
por Nintai Neville Nfor JR
