Ir para o conteúdo principal
O Samsung Galaxy S5 Neo (SM-G903F) possui uma tela Super AMOLED de 5,1 polegadas com resolução Full HD. Ele conta com câmera dupla, sendo a traseira de 16 MP e a frontal de 5 MP. Equipado com processador Exynos 7580 de 64 bits, 16 GB de memória interna, 2 GB de RAM e bateria de 2.800 mAh, ele mede 142 x 72,5 x 8,1 milímetros e pesa 145 gramas. Em comparação com o S5 original, o Galaxy S5 Neo apresenta melhorias como câmera frontal, rádio FM e LTE mais rápido (Cat6).
Phone display doesn't work even if the LEDs work
So for the first time in a long while i taken off my armored case for the Galaxy S5 Neo,wich became the worst decision as i reached for it when i got a call and it fell from my pocket.
The back cover fallen off as well as the battery,i pick it up and put everything in and try to turn it on.
I can feel vibrations and the top and bottom LEDs working but the screen will not turn on or anything like its not even connected.
I tried to take the battery out and turn it on in safe mode to the point i even slapped it on my hand like a TV remote in hopes that it will magically work but unfortnately nothing changed.
I'll soon will give it to my uncle that deals with this stuff but i was hoping that someone might have a solution in the meantime.
Thanks for even reading this and all!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Your going to have to get the screen replaced.
Once phone loses display as a result of dropping it it's always the screen at fault.
Esta resposta foi útil?
Pontuação 4
1 comentário:
yeah,the LCD hot destroyed in the end (that happens when you try to open it without a heating device) so imma wait for my uncle to come back from vacation and see if i can get it replaced easily!
por
Adicionar a sua resposta
Aleksander Smółka será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 14
Ao todo: 521
