Ir para o conteúdo principal
The first Android smartphone from Google, the Pixel XL (Model Number: G-2PW2100) was launched October 20, 2016. It has a 5.5-inch AMOLED display, 3450 mAh battery, and 32 or 128 GB storage options.
71 Perguntas Visualizar todos
Can the finger print scanner be painted or have a wrap applied to it?
II'd like to change the color of my Pixel XL fingerprint Scanner. I've seen durability test videos where they highly scratch a scanner and it still works. I've also seen cases with a thin plastic film over the scanner that still allows it to function.
I'd like to ideally remove the paint currently on the fingerprint scanner and repaint. Alternatively, I'd settle to have a wrap applied to it.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
Seeing as slick wraps provides skins that also stick to the fingerprint scanner i'd say that it still works with a sticker on there, i'm not too sure about paint seeing as that is a lot thicker than a sticker
Just a thought..
Here is the link to my example: https://www.slickwraps.com/galactic-seri...
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thanks so much, that totally makes sense. they're so cheap, I might just buy one and try and paint it to see what happens
por
Adicionar a sua resposta
Helpful será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 16
Duração total: 2,964
