Ir para o conteúdo principal
2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
467 Perguntas Visualizar todos
Mac does not turn on with power button
MacBook is not powering on or off with the powerbutton. Tried other keyboard without succes. The strange thing is, when i disconnect en reconnect the battery and connect the MagSafe with charger the MacBook turns automatically on. What could be the problem?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Bad keyboard usually from water damage, but check the keyboard to logic board connection. See step # 25 of this guide:
MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement
Esta resposta foi útil?
Pontuação 1
1 comentário:
I tried with a new keyboard but same result. All keys are working except the powerbutton (if that is the case)
por
Adicionar a sua resposta
Mattis será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 65
