Ir para o conteúdo principal
Released September 2016. Identified by Model No. SM-G610
164 Perguntas Visualizar todos
"IMS Service has stopped" message appearing every 15-20 seconds
The message "IMS Service has stopped" just started appearing every 15 to 20 seconds on my j7 prime, and i would rather not factory reset. How do I fix it?
Esta é uma boa pergunta?
Pontuação 3
1 comentário:
The past hour it w ont stop posting ims app has stopped. Keeps poping up.
por
Adicionar um comentário
2 respostas
I cleared two cache areas. Messages of error still showed up, but then I just restarted my phone.
First Cache
1. Go to Settings
2. Select Apps
3. Scroll to find "Messages" App, Select it
4. Tap Storage
5. Tap "Clear Cache"
**DO NOT CLEAR DATA**
Second Cache
1. Go to Settings
2. Select Device Maintenance
3. Tap Storage
4. Clear unnecessary cache data
RESTART YOUR PHONE
hope this helps~~
Esta resposta foi útil?
Pontuação 0
does not works. i did it several times. it should be a different way to get this fix
Pontuação 0
1 comentário:
Ayone found a working solution to this probem?
por
Adicionar a sua resposta
Clara Millar será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 11
Duração total: 32,139
