Ir para o conteúdo principal
Lançado em junho de 2009, o 1005HA é identificado por seu design de "Concha do mar" e está disponível em diversas versões com diversos sistemas operacionais e armazenamentos internos, assim como baterias de diferentes tamanhos.
24 Perguntas Visualizar todos
How do I return my graphic object?
I edited my graphic work for a long time in AutoCAD, before the program crashed. I just uploaded my file, made the day before, to the program for further processing, but after a crash in AutoCAD, I now don't see fragments of objects. This is impossible, because I didn't delete it.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Can you view the file here, using Autodesk's online file viewer? If not, then it's probably corrupt.
• Go into the same folder as the DWG file, and look for the same named file, but with a .BAK file extension (You need to have file extension TURNED ON).
• This is the last save before your last save.
• Then rename that file from BAK to DWG and try that one.
• If that doesn't work, then go into your %temp% folder (in the address bar of Windows Explorer, type in %TEMP% and press enter).
• Sort by date and look for a file name similar to your original file, but with a .SV$ file extension.
• Rename that to .DWG and try it.
• This is your last Autosave file (it may not exist)
• If that does not work, look for the same named file in the %TEMP% folder with a .BAK file extension.
• This will be your next to last autosave file. It may not exist either.
• If it does, rename it to repair autocad file and try to open it.
Source:
https://knowledge.autodesk.com/support/a...
http://www.thesourcecad.com/recover-dama...
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
NickyGreer será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 45
