Ir para o conteúdo principal
Plastic seating devices for patios, poolsides and bachelor pads.
How to fix a fixed stripped Table Leg?
Hi All,
How can I fix a stripped Table Leg? The leg has built metal treads, leg is stripped and no longer stays in.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
I also had such a problem, I never solved it. The table is in the garage
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Take any thread(the kind you sew clothes with) and wrap it around the stripped side of nut counter clock wise. Go around the nut with thread (if thread Is pretty thin) counterclockwise at least 4 times and than screw it in to other piece.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Danny Chiu será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 713
