The sound keeps cutting out on vizio
The sound keeps cutting out on on my vizio tv
Esta é uma boa pergunta?
There could be a number of reasons for this, but a few questions first:
1) When the sound cuts out, does it return on its own or do you need to shutdown and restart the TV?
2) Do all other functions work on the set as expected even when the sound fails?
3) When does the sound cut out? Right away or only after the set is on for a while?
4) What is the model number of the set?
As another test to check whether or not the speakers are the problem: Hook up a set of known good external speakers. If that works OK, then the internal speakers have a problem and should be replaced.
Dan
Esta resposta foi útil?
1 - returns on its on
2 - all other functions work
3 - right away
4 - M550SL
I have a Vision 55-50M and it does the very same things as the one up above
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 17
Duração total: 8,281
5 comentários
when the sound cuts out, the picture on the tv becomes distorted as well. then the last sentence is repeated. It does this after being on for several hours. When it does this, it continues on its own and eventually fixes itself. Model #:VIZIO E321VL.
por sandeejones
I have to shut it down and restart tv.
por kmacaa
Sound keeps going on and off and sometimes picture becomes distorted
por karen vidler
1 returns on its own
2 all other functions work
3 after on for
por Rod
@kodiak2018 is this a question, answer or a comment? You may need to clarify
por oldturkey03
