Where can I get a Windows 7 Start Up Repair / Recovery disc?
Where can I get a Windows 7 Repair. disc?
Esta é uma boa pergunta?
You should be able to create a set of factory recovery disks by doing the following:
1. Get some blank DVDs -- either DVD+R or DVD-R. You will probably need four, but I suggest you have a few extras, in case any are bad. Also, get a permanent marker, so that you can write on each disk -- "Disk 1", "Disk 2", etc.
2. In Windows, select Start / All Programs / Recovery Manager / Recovery Disk Creation. Follow the on-screen instructions.
http://www.hp.com/ctg/Manual/c02641795.p..., page 108.
You should be able to download or purchase the set of recovery disks on DVD or flash drive; but I'm having a hard time finding the info on line.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 281
If you have the product key use it to down load the ISO from Microsoft.
If you have a running windows 7 machine you can build one on the windows 7 machine. You did not say why you need it, do you need your system repaired or what?
por altbell
